各位大佬,大家用的是什么手柄
我用的地面站是QGC,飞控是pixhawk2.4.8,树莓派3B,手柄是小米蓝牙手柄,但是在进行设置的时候总是不能校准。会显示:joystick support requires MAVLink MANUAL_CONTROL support .The firmware you are running does not normally support this .It will only work if you have modified the firmware to add MANUAL_CONTROL support.
这个错误信息可以通过重新刷写最新版本固件解决
