O-Ring Flange Mounting Hole Dimensions
Hi there! I am searching for the inner mounting hole dimensions of this product: https://rovmaker.org/product/o-ring-flange/ for OD 110 mm.
It would be great to know how far away from the center axis the 4 mounting holes are, so I can design some brackets to attach internally.
Thank you
I hope it’s will work for you
